Copy mail on a folder sent
  • 21 views
  • Last reply by Yu5tiqX9og
Hello,
I am using Thunderbird on a Huawei P30 Android with EMUI 12.
Emails sent from my mobile are not being copied to the "Sent" folder, neither on the smartphone nor on the server. As a result, I cannot find them on my phone or on my PC running Linux Ubuntu 24.04.
Did I forget to configure something in the app on my smartphone?
Thank you.
Fabienne
Hello, I am using Thunderbird on a Huawei P30 Android with EMUI 12. Emails sent from my mobile are not being copied to the "Sent" folder, neither on the smartphone nor on the server. As a result, I cannot find them on my phone or on my PC running Linux Ubuntu 24.04. Did I forget to configure something in the app on my smartphone? Thank you. Fabienne
"Settings" > "Accounts" section > tap the account you want to configure > "Sending mail" > tick "Upload sent messages (Upload sent messages to Sent folder after sending)".
